Old 12-21-2011, 04:37 PM   #9 (permalink)
drmiller100
if you really dig into your harness, you will find about 50 wires throughout the car, including the engine compartment, which are black and yellow.
There are 3 of them into the ECU alone. black and yellow mean "ignition switched 12 volts" in the wiring harness.
You really need to strip the wires by the connector at the alternator to get the right one.
