Old 12-23-2011, 08:11 AM   #12 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by jakobnev View Post
Heating the air increases the volume that passes through the turbine.
Yes but heating does not increase the mass. If you don't send more mass airflow over the turbine, do you think it will perform better?
What throttle plate pumping losses?
I meant your turbine throttle, typo. You have to take airflow, turn it into rotory motion, and turn that into electricity or torque via some driveline.
How many hp do you think are available at low/mid throttle and rpm for say a 2 litre engine for your contraption? How much after the conversions? if it is less than 100% efficient at converting the incoming air back into vehicular propulsion then it sounds like a losing scenario to me as compared to no throttle.
Unless you are talking about diesels i don't see how direct injection eliminates throttle losses.
There are direct injection gasoline engines, becoming more and more common. If they made it with a throttle plate then the designer would be promptly fired.
