Old 12-23-2011, 09:04 AM   #17 (permalink)
user removed
Lets assume that throttle restriction is energy costly (it is), when an engine uses a throttle plate to control air flow into the engine. I guess the question is can you extract enough energy from the restriction to make it worthwhile?
I never really thought it was that much of an energy loss since the most pressure differential you can have is 14.7 PSI (give or take depending on atmospheric pressure).
Would any system be sufficient to do the job of the alternator?
regards
Mech
