I live in and commute Houston daily. drive between 55-60 mph and pump up the tires to max sidewall those alone you will see fast gains. also the full belly pan will do alot and see if your truck still has the factory chin spoiler on it. After that look into the bead liner. on the fluids since it dont get that cool here for us we can get away with alot thinner oil than most.
