So I went back outside, in the lovely ohio weather we have (cold as hell).
Took some measurements and pictures
Picture of the grill:
Top grill is 38 inches across and 4.75 inches top to bottom
Bottom grill is 35 inches across and 4 inches top/bottom
I realize gaping space is disastrous for aerodynamics however, I must ask, which should I block? does it matter in the sense of which is higher? I know the lower your car is the better gas mileage you get cause less air is getting under it, but does that count here?
Second order of business is gaps in the bumper.
What could I use to block these? would some spray painted duck tape work??
Third: Bottom of the bumper, where the underbelly would start:
I'm sure I can do a mount for an underbelly, but I'm not sure I want to extend it too far, my concerns would be draining oil... (though I don't change it much hah)
Is there an inexpensive way to fill the gaps of the headlight housings?
LASTLY!!!! The retched antenna, could I run a wire to the body and just bolt it there? Would that cause any kind of grounding issue? Would it cause any issues with the radio?
Help me out here!!! I'm a noob at this stuff!
