Old 12-24-2011, 09:50 AM   #30 (permalink)
user removed
Originally Posted by drmiller100 View Post
Did you try it, or are you just talking your perception of theory?
If you tried it, you will find you are wrong.
Then to rationalize, when you have WOT (or a diesel) you compress 10:1 or 20"1 compression on the compression stroke, but you get all that energy back on the power stroke - kind of like a big pneumatic spring.
You never get all of the energy back in any IC engine, unless you wish to ignore carnot's law, and yes I have tried it. I recommended it on this site years ago as a way to separate compression-suction losses from mechanical losses.
Coast in neutral
Coast with engine engaged and downshift at exactly the same points where you would normally up shift.
Do the same with the throttle wide open.
Push the car to the same speed and downshift at the same points as the previous test.
The "you get it all back statement" basically assumes there are not other losses involved when there are always losses involved. Moving air through an engine requires more work than sucking against a restricted intake. The rationale of you get it all back would apply equally to the vacuum scenario as it does to the compression scenario.
I have tried it, have you?
Tell you what, have you ever tried a compression test with the throttle closed, then realized you needed to open the throttle to get a true reading.
When you do that (open throttle) the cranking speed slows down because compression increases the total resistance.
Tried it on my Echo years ago and it slowed down faster with the throttle wot.
regards
Mech
