Old 12-25-2011, 03:38 PM   #21 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
As far as the smooth hubcaps, I've though of (but not built) covers attached by coupler nuts to the wheel studs. Many wheel studs, including mine, stick out past the lug nuts. I'm thinking you should be able to attach the covers that way without removing the lug nuts. If you couldn't get coupler nuts you probably could use regular nuts and some threaded rod. Might want to use some loctite too, to make sure they don't come off.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
