Old 12-25-2011, 05:26 PM   #20 (permalink)
Frank Lee
Originally Posted by IamIan View Post
However ... sense the question was about stability , CG is only one component of stability ... band-aid or not , the wider front two wheels is a valid method to improve stability.
It did not help them at the X Prize did it.
It is not enough for there to be a simple weight bias towards the two-wheel end on a trike. If you don't want oversteer on a tadpole- and you probably don't- you need to look at the load on each tire. When you do that, you can see that you can have more weight "on the front" yet still have more weight on that singular rear contact patch if the weight isn't biased forward ENOUGH.
IamIan (12-25-2011)
