Old 12-25-2011, 07:32 PM   #23 (permalink)
IamIan
IamIan's Avatar
Originally Posted by IamIan
However ... sense the question was about stability , CG is only one component of stability ... band-aid or not , the wider front two wheels is a valid method to improve stability.
It did not help them at the X Prize did it.
Well actually it did help.
It did improve stability.
Stability was part of the competition.
Help yes ... compensate for all other Aptera deficiencies compared to all other x-prize competitors in all other parts of the competition , no.
It is not enough for there to be a simple weight bias towards the two-wheel end on a trike. If you don't want oversteer on a tadpole- and you probably don't- you need to look at the load on each tire. When you do that, you can see that you can have more weight "on the front" yet still have more weight on that singular rear contact patch if the weight isn't biased forward ENOUGH.
Perhaps.
'ENOUGH' depends on the context / conditions , and criteria of what is 'ENOUGH'.
I'm not them so I can't know for certainty ... but perhaps that is why it was originally designed to have the comparatively lighter motor in the rear as a rear wheel drive to keep the comparatively heavier battery component in the more forward position... but the new company management wanted it done differently ... good or bad , they pulled rank , and ordered the redesign.
Of course 2 tire front wheel drive pulls out / handles significantly differently than a one rear wheel drive pushes / handles ... which is another reason I think the choice to change has pros and cons.
