dude, those look really cool. Did you shape those by sanding down a bigger foam block?
IMO you will want to fiberglass them first. Bondo is really more of a surface prep, and not designed to be structural. It's very brittle and I suspect if you just layer bondo over the aluminum foil you will find it cracking like an eggshell and then flaking off. If you do a layer or two of glass this will give it some structural rigidity and the bondo can be used to smooth it for paint prep.
"You too can get 50 Miles per Gallon, all it will cost is your self-respect."
