12-26-2011, 10:48 PM
#39 (permalink)
you are correct
yes it would and
hardware and software to control when the two switch back and forth
as well
it is a bad idea to take heat from the exhaust as that will screw up exhaust flow , especially when there is plenty of extra heat and some pressure available from ducting the back side of the radiator ala
Meredith effect ...
gains would be small , but gains are gains
Originally Posted by Frank Lee
I think depending on configuration of the turbine it might need a throttle plate besides in order to achieve a low idle?
