Originally Posted by mans
mwebb, does that still apply if my skinny tire has 50 psi?
How well do your current tires roll with 50psi? in theory they should roll easier then a narrower tire at the same pressure.
Any idea if there are any 175mm tires out there that would fit your car that are LRR? you might find that they are going to work better and give you better mileage.
