Old 12-29-2011, 12:33 AM   #1 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
junk burn from misfire due to no spark
using a pizeo type differential pressure sensor in the exhaust
green trace
at idle
blue trace is spark from a 4 in 1 coil pack , 1 coil is not outputing any secondary spark as seen in the waveform by 1 missing spark signature every 4 spark events -
note
in the exhaust after the combustion event that did not happen
there is an increase in pressure as the fuel that did not combust , burns in the hot exhaust along with the 02 that was not combusted in the combustion event that did not happen .
junk burn , injector is working .
another way , change in crankshaft speed as measured by alternator out put , read text bubbles
the image above was culled from the image below , what you thought was "alternator ripple " is really change in alternator output due to variation in crankshaft speed
think out side the box -
The Following User Says Thank You to mwebb For This Useful Post:
redpoint5 (12-31-2011)
