Old 12-29-2011, 02:07 PM   #169 (permalink)
Arragonis
The PRC.
PS - Quick update with George.
I haven't posted about things for a while mainly due to life imposing restrictions on time - mainly Christmas and work, but I have tried a few things. Firstly the Nostril blocks didn't make any different on or off to the intake temps (as reported by the SG2), so I added a sort of WAI by adding some tubing between the area of the exhaust manifold and the intake tube for the standard air filter mechanism. Again no difference to the inlet temps. I think the research this guy made seems true (note the C1 is a badge-engineered version of the Aygo - same engine etc.).
While driving to work today, I did some checking on the intake temperature on my Citroen C1. Intake air temperature is very important. The ECU determines the amount of fuel to inject based on 3 important variables:
Pressure in the intake manifold
Engine speed (RPM)
If the intake air temperature is hotter, the air contains less oxygen. Fuel and air should be mixed in fixed proportion to get best combustion. The ECU regulates this continuously. So when the intake air is warmer, less fuel is added and the engine will produce less power.
So today the outside temperature while driving to work was about 15C. While looking at my scangauge I saw the intake air temperature.
It was 34C. Which is quite a lot higher then the outside temperature. This could mean 2 things. Either the air being sucked in to the intake track is warm or the air gets heated up while in the intake track.
I already ruled out the first one. I added a hose to the point where the engine picks up air and routed it to the gril. No difference in air temperature.
So when arriving at work, I removed the air filter cover, and used my IR thermometer to check the temperature of the valve cover directly underneath the air intake:
45C
So I think that explains the higher intake temperature. This is a shame, because power is wasted by the increase in air temperature. Every 7C rise in temperature costs more then 1% power. Adding over 15C to the air temperature equals to more then 2% power loss. Sounds like something worth fixing.
It seems to me that even with a WAI the intake temp is already higher than it can be made via blocking things off or adding more tubing, so I'm off this idea. Which is a shame as I would like to see if a WAI could work - the jury seems to be at best "out" on that one - Sentra-SE has done some tests already.
I'll refit the nostril blocks at some point, and the lower grill block is in place for faster warm ups now that the cold is here.
