Old 12-30-2011, 01:19 AM   #41 (permalink)
oil pan 4
I went from P235/75R15 firestone tires to 31x10.5R15 goodyear RT-S tires. The goodyears were nearly 2 inches taller and almost 20 pounds heavier per tire and truck fuel economy did not go down. I was fully expecting fuel economy to go down, but it stayed the same and may have went up slightly. The truck has a TH700R4 (overdrive transmission with a lockup converter) and 3.08 rear end gears.
If you don't bother to account for your new odometer readings with the larger size tires your fuel economy will appear to be going down a lot more than it really is.
