Thread: ElCon Charger
Old 12-31-2011, 12:05 PM   #1 (permalink)
TomEV
Ford Escort 2.0
TomEV's Avatar
Electricar - '89 Ford Escort LX Hatchback
ElCon Charger
Part of doing the upgrade to 64v in the Citicar was to source a new charger. I found that the ElCon PFC2500 can be programmed for 64v nominal, and is capable of using both 120v and 240v as input without making any changes - just plug it on to the different voltage.
At 120v, the PFC2500 is a 1.5kW charger; at 240v it is a 2.5kW charger. Either way, it is a little more powerful than the old Lester ferro resonant 1.4kW charger, and much faster when using 240v.
The main reason I wanted to use a multi-input voltage charger is to allow me to eventually use J1772 charging stations, and also to recharge at all the places I normally do that have 120v plugs.
Not as cheap as the open source charger at around $700 (tax, shipping, etc.), but still a good deal.
Next step is to get the parts to install the J1772 inlet.
The Following 2 Users Say Thank You to TomEV For This Useful Post:
MPaulHolmes (12-31-2011), Ryland (12-31-2011)
