Old 12-31-2011, 11:14 PM   #6 (permalink)
redyaris
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
I just looked up sprockets for the EX250 and PBI sprockets has the largest range; fronts are 13 - 18 teeth and the rears go from 33 - 60 teeth. what I am wondering is will the EX250 accept a bigger than 15 tooth front sprocket without having the chain/sprocket contact the case? for the rear going from 39 teeth to 33 teeth is a 15% reduction so 6500 rpm will be reduced to 5500rpm if you can add a 16 tooth to the front then an other 6.6% rpm reduction drops the rpm down to 5150rpm at 70 mph. at this point the full benifit of the aerodynamics will be achieved.
The Following User Says Thank You to redyaris For This Useful Post:
HHOTDI (01-19-2012)
