Old 01-01-2012, 11:45 PM   #46 (permalink)
Ken Fry
A Legend in his Own Mind
Ken Fry's Avatar
Originally Posted by mans View Post
he gained 5 mpg with the doughnuts on his rear wheels. that would show that doughnuts are pretty good, way better than stock tires!
whats up with that?
thats a total conflict of results.
can anyone explain how this can be?
If you use this calculator, (Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com) you will see that the tires he took off may have had a Crr of .012 (who knows to what pressure they were filled?). The donuts may have been .009 at 60 psi. If you put in good guesses for a Metro, you can get 55 mpg at 50 mph. Then change only the Crr to .009. You get a little over 60.
I think MetroMPG used better controls.
The Following User Says Thank You to Ken Fry For This Useful Post:
mcrews (01-02-2012)
