2 Cylinder mod:
I keep coming back to your 2 cylinder mod idea, I like the idea of a 1L in fact. I just wish that a 1L would actually do a good job of moving a Jetta (I know even my 1.7L Rabbit felt all too peppy, a 1L would do it good I think). I would like to remove 2 rods and pistons and grind off the cam on those two cylinders to keep the valves shut, but I don't know how you could balance the Crank at that point. You would need to fake out the engine management, unplug the injectors and ground out those two spark plugs, but it could be done I think.
If you were headed that route already, it is possible a short crank and a 1.8L block could get you in the 1.2-1.4L range. I would love to see that actually, but in reality I wish I could source the stuff from Euro OEM, I am sure they have smaller engines in their line-up over there. In fact I wish the Polo would come out already over here.
