Old 01-02-2012, 06:20 PM   #50 (permalink)
kurzer
kurzer's Avatar
Knut - '07 Toyota Prius
90 day: 50.9 mpg (US)
Santa - '00 Hyundai Santamo
90 day: 29.07 mpg (US)
Originally Posted by Arragonis View Post
Do you have details on how it is wired up ?
of course, i did it myself.
the switch is an opener. the whole MPI is powered over a relais. the relais ground is connected to the ECU. this line ist cut open and the switch is inbetween. thats all.
the restart installation is not mutch more complicated. a normal car relais drives the starter. relais coil ground goes to a contact at the alternator. relais coil + goes to a clutch switch, further to a throttle switch, further to a service switch and than to switched power. thats it, basically. the black box, shown in the vid, is for batterie and first start supervision.
kurzer Gruß
Prius II
Hyundai Santamo
