Old 01-03-2012, 12:12 AM   #11 (permalink)
3dplane
3dplane's Avatar
14 Mirage - '14 Mitsubishi Mirage DE
90 day: 68.74 mpg (US)
Originally Posted by Blacktree View Post
3dplane, where in Florida are you? There's a fiberglass shop in Daytona Beach called US Composites that has epoxy resin, and for good prices. If you're not nearby, you can mail-order it. Their website is uscomposites.com
I'm in north central FL. Thanks but I did a little experiment with the regular polyester resin and as long as I wrap the styrofoam with more than one layer of masking tape it will work fine!
In the pics:
The pointy piece of foam got chewed up where only a single layer of masking tape covered it. It has stripes because where the tape overlayed,the double layer protected it!
Of the two dome shaped pieces one was covered with clear tape + masking tape= ok. The other was covered with clear tape + alu foil = ok!
Since I already covered the large fairing pieces with alu foil,I decided to put a layer of masking tape on (for a smoother surface)and start fiber glassing them as time permitted. The surface is a bit ugly but that's what bondo and paint is for
See pics.
Thanks!
Barna
Name:	resin (Medium).jpg
ID:	9976   Click image for larger version
Name:	resin2 (Medium).jpg
ID:	9977   Click image for larger version
Name:	resin3 (Medium).jpg
ID:	9978   Click image for larger version
Name:	resin4 (Medium).jpg
ID:	9979   Click image for larger version
