Old 01-03-2012, 08:02 AM   #72 (permalink)
Frank Lee
Originally Posted by Arragonis View Post
Being Frank for a moment, that is an incomplete answer. Why does it give you these advantages ? The devil is in the details.
It's easier to teardrop a body with one wheel on one end.
Maybe tires are not as sensitive to scrub as I imagine, but one wheel should not suffer side scrub by itself from imperfect alignment/track changes through suspension travel.
One spring/damper assy ought to be lighter than two.
Trikes aren't mainstream because they are more load sensitive. The lowest common denominator users out there can't be trusted with that. Add wheel #4, gain lots of safety margin.
