This suggests it is because they wanted to limit frontal area and rolling resistance to an extreme level, even limiting the effect of the steered wheels.
PAC-Car II is equipped with 3 wheels; the single rear wheel is powered and steered, and the front wheels have a camber angle of -8°.
This solution allows the reduction of the frontal surface area because the room needed to steer the wheels is not needed. Some experiments on a test bench have shown that this camber angle does not provide too much rolling resistance.
So they put the steered wheel at the rear where it would be shielded by the bodyshape, and the two at the front in a fixed position to minimise RR. It did its record breaking at 18 MPH though.
