Old 01-03-2012, 08:24 PM   #320 (permalink)
NeilBlanchard
Renewed big effort to make progress building CarBEN EV5!
I've been beavering away on the DataCAD drawing for CarBEN EV5, and these are the 42 sections forward of the high point on the roof; starting at the very front of the nose:
The front sections are ~1" thick because the transition is rapid, and the "stacked" sections are where I need to use a shallower depth to stop a feature. The majority of them will be 1 15/16" thick though -- there are about 85 of these, so this represents less than half -- and they are not done yet. There are five and a half sheets laid out -- I will know how many it will take to do the whole chassis when I finish this!
I will be using 1" thick foam sheets and just cutting two of each. This will let me use the bits I have and the machine will handle them a lot better without any farther futzing with the high current driver board and X-axis stepper motor.
