Old 01-06-2012, 01:00 AM   #23 (permalink)
Photonfanatic
Well once you get those on you're going to move on to other things. Plenty of people here seem to be past that point.
Originally Posted by niky View Post
The most likely explanation is simply that you're running leaner with your PCM re-programming but within the safety limits of the system..
Seems like this might be a viable ecomodding method as well. Maybe you could safely lean out something like... 10% of the total fuel used without harming anything. That's a 10% boost in gas mileage if so. A big jump for a lot of people here.
