Old 01-06-2012, 09:11 AM   #6 (permalink)
Daox
Originally Posted by tradosaurus View Post
I bought a 2000 Mazda Protege LX (1.6L) with 5 spd a month ago. I was planning on cleaning the EGR but noticed it was removed. The pipe from exhaust manifold was removed and the opening plugged. The vacuum line to the EGR sensor was removed but the electrical plug is still in. The EGR valve is removed and I frankly cannot even see where it would have attached to the intake manifold or throttle body.
Keep in mind that UFO is doing this on a diesel engine. Most gasoline engines benefit in power, mpg, and emissions from using EGR. In diesels its normally mostly an emissions tool.
The Following User Says Thank You to Daox For This Useful Post:
WesternStarSCR (10-27-2012)
