Old 01-06-2012, 06:19 PM   #22 (permalink)
user removed
Could you just connect them in a paralled cricuit with two sticks in each circuit then use a standard automotive type charger. You would end up with 10 sets of two sticks and they should charge to about the same as a standard lead acid battery. The amperage would be spread out in .1 increments. Might take a while.
Just a guess on my part.
edit: I think I got my math wrong, was trying to figure out a way to use what I already have to do the job. Nominal stick voltage would be about 9 volts?
regards
Mech
