If you look at the math then larger is not going to help, the only thing that a larger muffler will do is help you keep your foot off the gas by making your car loud when you give it to much gas, this makes side by side testing hard, but if you do a lot of highway, steady speed driving then for sure a smaller exhaust pipe will flow better because after all exhaust is pulses not a steady stream.
