Old 01-06-2012, 10:56 PM   #27 (permalink)
jamesqf
Originally Posted by IamIan View Post
I've done the subpack testing without removing the subpacks ... or disconnecting the orange terminal plates on the two sides ... it has risks , because the connected voltage is higher than with the side connection boards off ... but a set of alligator clips can connect to the + of one side and the - of the other side and do one subpack at a time that way ...
More convenient still, I've found, is to get a couple of ring terminals with diameter large enough to accept the bolts that normally connect the sticks in the pack. Undo all the bolts (thus eliminating the risk of current from all the batteries), and use a couple of the metal stand-off pieces (the thick metal "washers") that are in the terminals that are outside connections to screw the ring terminals to each stick to charge it. A cordless drill with a 10 mm socket is a great help here.
The Following User Says Thank You to jamesqf For This Useful Post:
IamIan (01-07-2012)
