Old 01-07-2012, 03:09 AM   #9 (permalink)
oil pan 4
Originally Posted by drmiller100 View Post
where do I find a 50 amp, 60 volt charger cheap?
You could use a varriable AC transformer (varrac) and charge at what ever voltage you want. They can be had on ebay for cheap I bought my 300v 5kw varrac for $180, smaller can be had for a lot less.
I am sure you can pick up a small varrac for a lot less than a 48v DC charger.
Also you could automaticly control the charge time with cheap lamp timer or light switch (or heat lamp) timer from lowes.
