Old 01-07-2012, 04:45 PM   #15 (permalink)
moorecomp
Originally Posted by drmiller100 View Post
I have 4 batteries in series. I want to charge them at once with 120 volts.
Seems to me 12.6 times 4 equals 50.4
Seems to me alternators normally charge batteries at 14 volts. So, it seems to me if I charged at 60 volts DC, I would be pretty close to perfect.
So if I take 120 volts, and stick a diode in it the right direction, I'm gonna kill one leg of the AC current, and have 60 volts peak charging my batteries.
Obviously it is not this simple, so what am I missing?
120 vac, or your "normal" house current, only has "1 leg". If you look at the sine wave, it goes up to 120v+ and then down to 120v-. A diode cuts out the negative side of the wave and you end up with only peaks of 120v+, not 60v.
