Old 01-07-2012, 05:03 PM   #5394 (permalink)
Ken6881
Im glad i could help you on that under power it will simply reset and if you have the pre-charge feature turned on it waits until its finished then goes right ahead and works great. While driving we had this happen i would say 5 times or there about until i turned the pc time to zero (currently contractor is on a switch) then it would loose power until you let off the gas and pushed it back on and it would pick right back up. only problem we had was trying to set the bat amp limit it would never take 3 digit amp limits. if you typed in 500 you would get 50 or 250 you would get 25 not sure why that was but we were about sick the first time we pulled out and had about a 5mph top speed. set it back to 000 and drove it.
