Originally Posted by Ecky
Does the insight turn off the engine during coasting anyway?
No, at least not at higher speeds. It'll shut off fuel to the engine (DFCO), but everything still goes around, and on a steep enough grade, you'll likely get some regen.
With a manual, it will shut off below about 18 mph, if you push the clutch in and brake - that's part of the autostop logic that shuts the engine off at traffic lights &c. Don't know how this works with the CVT, though.
