Old 01-10-2012, 10:11 AM   #6 (permalink)
drmiller100
I THINK what you have posted are two different maps for the same cam? One is low coolant temperature (cold engine) the other for when the engine warms up????
In general, retard the exhaust cam at low rpm. You are keeping the exhaust valves closed longer for every bit of power.
As you rev the engine up at higher rpm's you open the exhaust cams sooner.
