Old 01-10-2012, 02:09 PM   #50 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by DJBecker View Post
That module isn't doing very much. It's pretty much just a diode, two resistors and a relay that switches the second resistor into the circuit.
It would be more interesting if the board did more: provided an isolated pulse width signal to the charge controller (the allowed current draw is indicated by the pulse width), provided a motor controller "inhibit" output, or sent a CAN bus 'connected' message.
If I add J1772 support to the charge, I will be making it take full use of the pilot signal. I dont just want it to tell the EVSE that there is something connected.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
