Thread: Saturn TDI
Old 01-10-2012, 10:40 PM   #29 (permalink)
Josh8loop
Definately a Modder!
Originally Posted by Craig View Post
Nope, no electric hybrid for this one! I engineered a diesel engine swap, using the drivetrain out of a '97 Jetta TDI, which is fairly fuel efficient to begin with. Some tuning, some aerodynamic mods, and a LOT of careful driving/hypermiling techniques helps push my mileage figure up there.
Wondered if you had given any though to constructing a "Hybrid" 205 Deg F thermostat to bump up your MPG's further. Info can be found here:
Mk2 thermostats will work in the ALH, so I'm thinking it's also reverse compatable
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
