Old 01-11-2012, 02:12 AM   #9 (permalink)
oil pan 4
Originally Posted by DieselDrewski View Post
The Festy is powered by a 2 cylinder, 750cc Yanmar, with a placard hp of 13.4, and about 20lb-ft of torque. I added a turbo, but without increasing the maximum fuel delivered by the injector pump, the boost was minimal.
You can get around that pretty easy with propane fumigation.
You may want to try a VW K03 turbo with that kabota 950. If I can ever pick up a kabota 950 to build a generator I plan on using one of my K03 turbos on it.
The Kabota with a turbo may be just large enough to try water methanol injection.
