You can get around that pretty easy with propane fumigation.
You may want to try a VW K03 turbo with that kabota 950. If I can ever pick up a kabota 950 to build a generator I plan on using one of my K03 turbos on it.
The Kabota with a turbo may be just large enough to try water methanol injection.
Before all this tracker action started, propane was on my list of things to try. What size engine was the K03 used on? I used an IHI-RHB31 on the Yanmar, which is about the smallest one I could find, but still too big. I was thinking I'd use the same on the Kubota. I don't know about the water methanol injection, I'll have to look into it.
