Old 01-11-2012, 10:03 AM   #17 (permalink)
beatr911
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
Vic, I'd consider just going straight to the 15/33 gearing. The only real limiting factor here is if first gear is too high. You don't need to be in 6th on the freeway, just use 5th. With a super long 6th you will also be able to evaluate the improvements in aerodynamic slipperyness as it will become easier to pull higher and higher air speeds.
Good design is simple. Getting there isn't.
The Following 2 Users Say Thank You to beatr911 For This Useful Post:
greenjoe (01-11-2012), HHOTDI (01-19-2012)
