Originally Posted by Piwoslaw
Sounds like a few threads could use some of your expertise.
Great, looking forward to it
Not even a small project? Not even a grille block during the colder months? A small Kammback, barely noticeable to the untrained eye? Just a bit more in the tires? E?
This is going to sound bad
I only changed the tire pressure to mess with front and rear axle slip angles and, sometimes, took of the IC cover to lower the intake air temperature. Sorry, promise to make it up to you
Oh maybe I did some test on low 3,x bars (approx 50psi) but didn't like the feel. I'm as much into driving technique as in the engineering. Again, very sorry
