Old 01-11-2012, 06:25 PM   #13 (permalink)
aerohead
will they
Originally Posted by Big time View Post
Will they improve aerodynamics?
They have some cutouts in the hood to allow hot air from the radiators to exit.
Lotus Elise - Wikipedia, the free encyclopedia
Proper inlet and outlet ducting can render cooling system drag nearly zero,adding about 6% mpg.
My only reservation is,with a 'high-time' vehicle,hose can blow as well as upper radiator manifolds.(I've experienced both)
Should you be at speed,if the coolant makes it onto the windshield you could be blinded instantly with a very brief event horizon before you crash into something-somebody.
