the cyclone valve is at crankcase pressure so ..
Originally Posted by Josh8loop
I'm actually not sending boost pressure directly to the crankcase. I bleed a VERY small metered amount of boost air from the lower intercooler downstream of the crankcase but upstream of the cyclonic separator. This bleed ensures that I have no significant amount of oil accumulation in the intercooler, and helps to aid the effectiveness of the cyclonic separator. I am getting a little more than 1 ounce per 10K miles.
The other benefit of the system is that it provides visual feedback of turbo oil seals and also the CCV oil throughput. The other benefit is that it helps reduce EGR valve clogging a small amount. I wouldn't swear to it, but my gut tells me I may have increased my mileage a small amount with the addition. I'm at 60 MPG in Florida city traffic for the last 4 tanks of 800 miles each tank-Plus it's darn cool!!
your PCV / Cyclone valve is at crankcase pressure , if you add boost to it from the intercooler which does have boost if your turbo is functioning ,
then your crankcase will operate with boost , pressure above baro when the system is boosting
and
you have misplaced the air ducting for the intercooler which renders it useless for it's original purpose
now
your intercooler is a large boost accumulator , with trace amounts of engine oil from the failing center bearing of your turbo
that is not darn cool
because
the
pcv cyclone valve should drain to the oil pan
there is no benefit here only detriment
Reason: pcv cyclone valve should drain to oil pan
