i do not think so
reduced MAF signal will result in
less fuel to the system , greater FE , leaner mixture or same mixture when EGR is active , just less of it .
EGR operation reduces MAF flow
EGR functions by DISPLACING area in the combustion chamber with an inert gas
exhaust ,
thereby
reducing the available engine displacement volume and combustion pressure during the time EGR is in operation
how do you suppose eliminating EGR will increase FE in your system ? theory says no .
the ALH engine does have intake restriction via a throttle valve to enhance EGR flow and
to shut the engine off when key is switched to
off
a 2001 beetle would have an ALH engine ?
i also have VCDS
and use it daily - today it is version 11.1- i also use the actual VW scan tools ,
imho you should register your VC software as there are many additional things that will be made available ....
i would not use any software to tamper with the Mother VW settings in engine management .
do not use bio diesel , ever , in any VW diesel engine , another subject .
Reason: do not use bio diesel in any VW engine
