I just turned 381,200 on my 97 HX ,I run full syn valv 5w20 engine and transmission ,still have original clutch and all ball joints ,car runs great,ngk plugs ,and check the egr ports under the fuel rail they plug up with carbon and affect gas mpg,i clean mine every 100k. I change oil evey 7500 like the book says and timming belt 100k. Great car
Originally Posted by Titanium
I bought a 1997 Honda Civic HX that has a manual transmission from the original owner two days ago. The car is 100% stock, in very good condition and it runs great. This car has 167,000 miles on it.
When I buy a car with higher miles I like to change the engine oil, manual transmission oil, antifreeze, fuel filter, give the car a tuneup with new spark plugs and anything else it needs before I start driving it. I was thinking of using Pennzoil Ultra 5w-30 synthetic motor oil with a Mobile 1 extended performance oil filter on this car. I'm planning on driving this car over 400,000 miles...
I was reading the owners manual on recommended fluids and spark plugs for this car. Of course the manual says to use Honda fluids from the dealer.
What brands and types of fluids are you guy's using in your Honda HX's?
What spark plugs are you guy's using?
