Old 01-12-2012, 09:20 AM   #19 (permalink)
Josh8loop
Definately a Modder!
Originally Posted by mwebb View Post
your PCV / Cyclone valve is at crankcase pressure , if you add boost to it from the intercooler which does have boost if your turbo is functioning ,
then your crankcase will operate with boost , pressure above baro when the system is boosting
and
you have misplaced the air ducting for the intercooler which renders it useless for it's original purpose
now
your intercooler is a large boost accumulator , with trace amounts of engine oil from the failing center bearing of your turbo
that is not darn cool
because
the
pcv cyclone valve should drain to the oil pan
there is no benefit here only detriment
Not sure you caught just how small my bleed line is from the lower intercooler? It's 1/8" diameter, and about 6-8 feet long.
Not sure you caught the fact that my cyclone separator is not a stock component for my car and was added to aid in oil removal from the intake.
The bleed line is essentially a capillary tube. You cannot physically drive much volume through it(since it's so small in diamteter) at such low boost pressures. Let alone the fact that it is carrying small slugs of oil through it occasionally(Enough for 1.1 oz per 10K miles) which further reduces the volume it can move. It also enters the CCV system at the elbow on top of the valve cover in a way that will allow the VERY small amount of air that it bleeds to entrain additional crank case gasses essentially scavenging the crank case to a very small degree.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 60+ MPG City. Nokian Entyre Low RR Tires. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
