Old 01-12-2012, 08:50 AM   #7 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by slowmover View Post
The way you and I are running these trucks -- low-rpm, low-load -- there will be some carbon build-up at the injector tips and in the combustion chambers. A cleaner is going to help this problem somewhat. I'd still rather run it hard to redline once a month or so, maybe in Third, but definitely in Fourth and Direct.
Yeah, I've wondered about that. The thing is I actually do run fairly high loads during my pulses in P&G. Of course, that's followed by my glide at idle. And even though the pulse should lead to some fairly high temps, it's for a fairly short period of time. So...I don't really know
You're probably right that it would be worth it to "burn it out" every so often. I know soot build up can be a problem with the VG mechanism, as well as other things. Occasionally (once a month or so) I do have to make a trip out on the interstate at 60-65 mph, but even that won't really push my engine at all when I'm unloaded and in 6th gear.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
