Old 01-13-2012, 05:33 AM   #33 (permalink)
oil pan 4
I have used PTFE in engines before.
The one where I used it the most was my 6.5L diesel engine build.
I sparyed the main and rod bearing shells with a light coat of remington dry PTFE spary, then put a fairly thick coat on the injector pump driver gear and used a PTFE and wax "dry chain" lub on the timing chain.
