Old 01-14-2012, 12:40 AM   #5433 (permalink)
DJBecker
Originally Posted by sawickm View Post
Do you have to worry about vibration cracking the solder joint from the soldered source pin - copper strip - busbar connection? I might not be visualizing that correctly?
It doesn't look as if we took any pictures that show the finished result. We were trying to get the same same effect as PowerTab or SuperTab part -- a wide, flat tab for both the source and drain connection.
The copper strips are soldered the whole length of the pins with a generous amount of lead solder, so I don't expect enough mechanical stress to cause cracking.
The Following 2 Users Say Thank You to DJBecker For This Useful Post:
MPaulHolmes (01-14-2012), sawickm (01-14-2012)
