Old 01-14-2012, 02:40 PM   #6 (permalink)
nemo
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Originally Posted by Shepherd777 View Post
I have a Chevy Impala LTZ. I was changing the oil last week, and while it was up on ramps I noticed the air dam configuration.
It's a 3 piece deal, with a gap between the outboard sections.
What I can't figure out is their reasoning. Why is there a gap between the sections? I mean, obviously they want to let some air between the tire and the engine cradle. But why? Again, this is a Impala, not a Corvette. I don't really get the brakes that hot (usually) that they need inboard cooling.
And while you are pondering that riddle, why on earth are they terminating the curved outboard sections 2/3rds. inboard from the outside of the tire??? If I was doing it (before I saw this) I would have extended those outboard sections so they flow the air around the outside of the steering tires. Not slam right into them at 1/3 from the inside. ???????
Also note the center portion is not below the aluminum cross member. I believe the reason for this is so that it will clear most parking stops. It is the same configuration used on my 06 Grand Prix.
Now.
The Following User Says Thank You to nemo For This Useful Post:
aerohead (01-14-2012)
