Old 01-14-2012, 08:11 PM   #10 (permalink)
mans
I plan on doing some tests on my spare delco 95a alternator with no load (with and with out the little stamped sheet metal fan), and power steering pumps to see how much power it takes to turn them.
in your tests if you are using a belt tightened up to equal the tension in the car, you will find out if any power is lost due to the belt.
a belt when it's off the car usually falls to a natural position. when its in the car its tight around the pullys. perhaps that takes up some energy when it turns?
the folks here don't seem too concerned with that, I assume it isn't much.
in your tests you'll find out how much that is. let us know.
